Is it possible/ok to connect a B80/AC60 system to the ac outlet on a B300 to charge the B80?
@kwetherington
Are you referring to using the B300 battery pack to charge the AC60+B80 system?
The output ports on the B300 are very limited, so unfortunately it can’t be done.
Hi @kwetherington
if the voltage range of the MPPT start from 12V, than you could conenct the cig-Port on the B300 and the MC4 to AC60 Adapter on the other side to charge from B300. The other way around too.
