Just a quick shout out to see if anybody has found a suitable power supply to charge the B80 with, other than the Bluetti T200S.
The T200S works well but in an office environment the constant fan noise is excessive.
I have tried a 132watt 24Volt 5.5Amp plug compatible switch mode that did not work.
So I am hoping somebody else has tried to do similar and can point me in the correct direction.
For reference the B80 is being used to increase run time of an AC180 when grid power drops off.
Appreciate any help.
