B300K Alternate Cables
Does anyone know if anyone is making alternate cables to go between the AC300 and the B300K i.e. right angled so we dont have the great bit loop of cable between them, its very inconvienient having that loop taking up space?
Matt
Hi @addison.mj
as far as im aware, there are only cables with straight connectors. No connectors that are angled etc.
Thanks Erik, do you or anyone else know what the connector is, is it an industry standard, my thought was to design a right angled holder in cad and get it resin printed by a 3rd party?
Matt
I have never seen any Battery Expansion Cable at a 90 degree angle, and I have B300 and B300k cables.
It may not be possible to make it at an angle because the main DC contacts are large to pass 90 A, and there is a mechanical lock plus a slider switch in the handle. The only way one may make a sample connector at 90 degrees is to sacrifice one, cutting it open.
And, up to today, no Bluetti user knows who makes that special connector. But if someone does discover who makes them, please post it here. I am willing to buy one and do my own convetsion.
Agree, even if we can get hold of sacraficed male and female we could make a right angled adaptor using 6-8mm copper bar for the high current dc, this can be bent quite easily to right angles and soldered to the 2 connectors then is just a case of doing passthru for the data lines.
Matt
I put a loop in mine so they take up a little less space.
