Ma B230 is connected to the AC200MAX with cable P090D, classic.
I have problems with the B230’s load level indication
I have repeatedly made a cycle discharge/ charge on wall of the B230.
While it is charged via solar panel and D050S for several days, in the morning when I turn it on, it shows only one charge LED.
Connected to the AC200MAX this on show me a load for the B230 of 7%.
I have a big doubt, it should be charged to 80% minimum.
I then decide to turn everything off and disconnect the P090D cable.
By turning on the B230, I see that 4 LEDs are fixed and only the fifth blinks (solar load) and therefore, the indicated charge would be 80%.
What’s wrong with the 200MAX or the B230?
What can I do?
You don’t have the latest updates.
See below for my AC200Max and B230.
I had the same problems as you, and the update fixed everything for me.
If you still don’t have the latest versions after updating via the app, ask @BLUETTI_CARE
ARM V4008.06
DSP V4005.08
BMS V1017.07
HMI 6037.03
BMS1 1018.02
If it still doesn’t work, you can take a look at this post where I give workarounds that worked for me (solutions that I no longer need since Bluetti pushed a special update to fix the problem.) : B230: Is firmware upgrade even possible? - #2 by Snips1
Hi @wyse, It seems that the SOC(State of Charge) difference in your B230 before and after the restart is quite significant. We have a BMS firmware update that can fix this issue.
We have applied to upgrade your BMS. Our IT department will push the latest version of firmware to your machine in 24 hours. Please upgrade it tomorrow.
Please note that when upgrading the firmware, disconnect the AC200MAX from the B230 and upgrade the AC200MAX separately, and do not load any device when upgrading it.
After that, please try to do a complete cycle of discharge and charge to correct the SOC. The problem will be resolved.
Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
Please charge it again. Please do not load any device when charging it, and do not interrupt it while in charging.
Thanks to @Snips1 for the helpful explanation and sharing. It’s very useful.
Hi @wyse, Thank you for getting back to us so quickly.
We hope everything goes smoothly from here!
Since tomorrow is the weekend, we will reply to your next comment on Monday.
Hello, I have not received anything at the firmware update level.
I am well-connected with the latest version APP, but the Upgrade tells me that I am up to date.
We’ll see about that on Monday.
Have a good weekend
Hi @wyse, Thank you for the update — we’re really glad to hear that the issue has been resolved!
It seems the new firmware is performing quite well. I’ve also shared this good news with the R&D team.
I discovered a small bug following this update.
Now, when I turn on the B230 alone, it no longer indicates the state of charge, all LEDs are off.
I need to turn on the 200MAX for the LEDs to light?
The two batteries are connected by cable.
Curious. @BLUETTI_CARE
Hi @wyse, This doesn’t seem normal.
Could you please disconnect the B230 from other devices and test whether it can charge and discharge properly on its own?
Yes, the B230 standalone charges and unloads normally (I use a solar panel and a D050S).
I confirm that the B230 and the AC200MAX load and unload in the same way, it is still the B230 who reaches 100% first.
Regarding the display of the LEDs of the B230 on ignition (SoC), I need a few more days to confirm the anomaly (first turn on the B230, first turn on the 200MAX…), so that the information is accurate.
I think it’s not a problem with your unit, I also did the update and I also noticed this behavior: the 5 green LEDs of the b230 are off, even when the b230 is on, when the ac200max is off. But as soon as the ac200max is on, the green LEDs on the b230 light up normally. To solve this “little problem” my method: turn off both units ac200max and b230. On the p090a expansion cable, switch the blue button to “unlock” (there is no need to disconnect the big p90a cable). Turn on the b230 first. These green LEDs should light up normally. Then re-switch the blue button on the p090a cable to “lock”. Then turn on the ac200max. And that’s all ! The next time your ac200max and b230 are off, and you turn them on, even starting with the b230, its green LEDs will be on normally. It works for me anyway.
Hi @wyse, Thank you for the update. We are glad to hear that the problem has been solved.
Thanks for @Snips1’s suggestion. This method is really effective. We will share this solution with the engineers in the hope that it can help more users in the future.
Wish you all the best!
