B210 and Ac200Max
Is the Ac200max compatible with the B210 battery. Ive seen very little information on this. Ive seen one random video that seems to imply that it is and Ive seen one diagram that shows a cable needed for it but that cable I cannot find anywhere. Any ideas? I want to expand my system but I want a battery that I can use for multi purposes so Im not interested in the new B3000k as I want more than a usb port and since the B230 is no longer produced I see this B210 as the only potential option if it would work with the Ac200 max.
Hi @bdbrook1008
officially, the B210 is only compatible with BLUETTI AC200L, AC240 and the D100(S,P).
I have the AC200L which uses the same connectors like your AC200Max, but i think its just not supported on the software side.
You could have a look for a B300. This is also no longer in active production, but im sure there are some rest stock on some stores. The B300 can be also used as standalone DC Battery. It supports charging by AC and Solar.
Maybe @BLUETTI_CARE can say something about the compatibility between B210 and AC200Max
@bdbrook1008 Sorry, B210 is not compatible with AC200MAX.
Hmmmmm……
