B1232 battery
@BLUETTI_CARE Had an issue with my B1232 battery shutting down, green power light goes off, trying to see if the 2000w inverter pulling too much, I can restart battery, no red light or errors, now apparently my inverter recommends 210A battery output current ?. This single Bluetti battery is good for 140amp max discharge current or peak (310A @ 8 sec. according to the manual), At the time I tested a coffee maker, it was using 1400w, and pulling upwards of 125 amps, according to the inverter App, My question is, could this inverter be pulling too much for this B1232, Any chance Bluetti coming out with their own inverter LOL. Thankyou for any info.
Hi @JimyFX, thank you for getting in touch with us.
Please do not set the output to 210A, as this current exceeds the operating range.
A 125A coffee machine is compatible, but please note that the startup current should not exceed this value by a significant margin—otherwise, an error code may be triggered.
Many of our products are equipped with inverters; this standalone battery is simply a newly launched addition to our lineup.
@BLUETTI_CARE ,Thankyou for response, I originally purchased the B1232 to expand my RV12volt capacity and to recharge my AC200L Via d40 DC/DC charger , I do have another battery bank for the Inverter, but good to know the maximum wattage anyway,
Hi @JimyFX, you are welcome, it’s our pleasure to help you.
Thank you for choosing Bluetti!
