I am setting up a new AT1 and 3 x EnergyPro 6k system. AT1 is wired to gird and house, but not yet to EP6ks. Grid pass through is working fine.
I am unable to connect the AT1 to a wireless network – it appears the network chip isn’t receiving a signal. I have tried multiple 2.4GHz network access points and am unable to connect. RSSI shows one bar even though the antenna is about 10 feet away.
I updated the app and firmware to the latest versions. Bluetooth control has no problems.
I also ran an ethernet cable from the ethernet port on the AT1 to the back of my ATT router and it connects, is seen, and is communicating, but I can’t get the app to see it no matter what I do. Where is the data going? How do I see it?
The AT1 identifies as a Windows Phone, has a valid MAC address, and accepts a DHCP IP address. It doesn’t show any of it in the APP.
How is your EP6k + AT1 install? Were there any install issues? I am returning the EP13k’s I have due to several bugs with the AT1, it currently does not work very well. Since I already have an AT1 installed, if I can exchange them for some EP6ks, it would save time and money looking for another home backup system. Do you have 3rd party PV ac coupled via the AT1? Does it charge the ESS from Solar? Any grid charging issues or settings not working?
I had problems initially with network connectivity too, but did get there in the end after an AT1 firmware update, a few connection attempts and some power cycles.
Power down included total shutdown of the connected Hub-A1 and Apex 300’s because that’s necessary to make it fully dark - the on/off switch and breakers off is maybe not enough as the communications board seems to get some power via the CAN bus connection too and has some internal flashing LEDs you can see behind the orange cover.
Sorry I can’t be more specific about what path works for sure, but I did achieve a WiFi connection and then switched to hardwired ethernet. Network connection reliability seems to have been good since then.
[Current AT1 Firmware versions, IOT v30007.01.06 and ARM v9086.11]
