I recently updated my app to version v3.0.3. After the update was applied, I can not select the options under Working Mode.
I can go to into the Working Mode menu and see 4 options
- PV Priority UPS
- Standby UPS
- Time Control UPS
- Customized UPS
However, I can not select any of them as it has defaulted to Standard UPS. I normally use the “Time Control UPS” mode and set schedules when to charge. I can no longer see those schedules nor can I get into the options in Time Control.
Bit annoying that an update has somehow locked the Working Mode options out.
Anyone else having the same problem?
I have a AC500 unit with B300K batteries.
Hey @solarguy1
Did you check your unit for a update?
Sometimes Unit + App needs a update for a certain function.
Hi Erik,
According to the app, the firmware is up to date. No option to perform update at this stage. I have done updates on the unit firmware before but none available this time round.
IOT v9041.10
ARM v4048.04
DSP v4057.03
BMS v1067.13
I still suspect that the App v3.0.3 has a bug as others have reported the same issue.
Regards,
Graham
Hey Graham,
It could be indeed a bug, since in 3.0.3 they change something with the working modes. My EP2000 for example received a extra working mode. Could be they forgot something on other units.
@BLUETTI_CARE Could you report this to the App Team to have a look?
Hello @solarguy1 ,
Thank you for your feedback. I will submit this issue to our app testing team to try to reproduce it.
If possible, to help us reproduce the issue more quickly, could you please let us know:
The firmware version of your device
Your phone model
Your phone’s operating system version
If you have time, providing a short video demonstrating the issue would be extremely helpful for our investigation.
Thank you very much for your support!
