The Design of the old version was better.
Before the new update version of App Bluetti, When i am connected with Bluethoot, on the main screen bottom, there was a “KW product by PV (solar) meter”.
Now the Kw / PV meter is gone.
I am really unhappy, because it was very practical. Would it be possible to add it?
And why not to improve it ? adding the daily for example ?
Thanks in advance to the developer for this.
Avant la nouvelle mise à jour de l’App Bluetti, quand je me connectai à l’application en bluethoot, en bas de l’écran principal, il y avait un compteur “KW produit par les PV (solaire)”. Maintenant le compteur de Kw / PV a disparu.
Je suis vraiment malheureux, car c’était très pratique. Serait-il possible de l’ajouter ? Et pourquoi pas de l’améliorer ? en ajoutant le quotidien par exemple ?
I have a samsung Z Fold4.
It is not possible to go any lower.
The application does not allow me to go down far enough to see the Kw / PV meter.
The old version worked well.
Hello all,
I also had the problem that there was no display for the self-produced electricity in the app.
After reading the advice here in the forum, I tried to register the AC300 via Wifi. This did not work even after several attempts. Frustrated, I switched back to Blutooht and lo and behold, the display for the self-produced electricity was suddenly visible.
I think there is a small error in the app that is only fixed after an attempt to log on to the WLAN.
Wait – there’s a kWh meter? Does that also appear for the AC200 series, eg AC200Max? Or is that only for AC300 and above?
I’ve never seen it in any iOS or Android version for my AC200Max, since i started using the App last year.
I tried scrolling down for both iOS and Android and don’t see it, but might not be doing it right.
I think so.
After i am connected by WIFI, i have filled in my account (Username,adress,…).
In WIFI, no problem for see the self-produced PVs.
I have desactived the WIFi in my AC300 just Blutooth ON, now in Bluetooth mode it works fine. Conclusion: WIFI and Bluetooth, I have see the Self-produced of my PVs.
I’ve never seen it in any iOS or Android version for my AC200Max, since i started using the App last year. I tried scrolling down for both iOS and Android and don’t see it, but might not be doing it right.
Hi,
I don’t know if this is available on App for the AC200.
See if you have the same app?
and test WIFi and Bluetooth?
Maybe?
I have the same app, and tried logging in and not.
(AC200Max has no Wifi)
There is no meter, so it’s probably just not available.
I don’t know why it would matter which device it is
At some point it appears the AC200MAX had this feature in the app. This pic is from Bluetti’s pictures in a for sale listing. The AC2000P displays it on its screen. I just got the Max and now I miss this feature.
Oh wow. Thanks for sharing. @BLUETTI why was this feature removed?
That’s really too bad the feature was removed.
Perhaps AC200Max has hardware problems and is unable to properly compute it?
Thanks. But in the 2 years i’ve owned it, AC200Max has never had total PV generation.
It’s not there on iOS on an iPad.
Other Bluetti products have it, but not ac200max.
Can you confirm that it should be there for ac200max?
If so, there is an error, because it’s not there…
@jCs I’m sorry for my wrong information. I checked with the tech team again. AC200Max did has never had total PV generation. I think the picture is wrong and I will give feedback to the relative department.
