Apex300 numbers charging,output is every hour?
Hi,@bluetti_care ……do the numbers shown charging, in and out or Solar, are they every hour ? So multiply them by 24 to get daily watts hours used ? Thanks
Hi @JJDD, Yes, the energy statistics are updated hourly. However, the system samples the instantaneous power at each hour; if the Wi-Fi connection is unstable, it may cause discrepancies in the energy statistics.
There’s no need for you to calculate the total daily power hour by hour—our app will do the automatic calculation. Please note that the PV input power varies at different times of the day.
I just want to know what the numbers mean overall, same as with watts out, it shows 200-350 that varies , so these are hourly ?
Hi @JJDD, Yes, this data is sampled automatically at one-hour intervals, so it will change in accordance with actual conditions.
