APEX300 for rv renovation
Hey guys,
i am concidering buying an APEX300+Charger 2 and DC hub.
also important i am in europe!
The DC side is completly clear to me. i will connect my original dc breakerbox with an anderson to the DC hub in the garage,connect it to the charger 2, connect the solar panel and alternator to the charger 2 and this way i will only have 1 plug to put in the apex300 to supply and charge everything (the original leasure battery will be removed and replaced by the apex300)
However i am stumped of the best use for AC power.
My RV has a CE plug that goes to a breakerbox and supplies 240V to the various plugs,fridge and a AC to DC charger wich will not be used anymore.
What is the best way to charge/supply AC with the APEX300 in europe? Idially i want one plug to connect to the apex300 that supplies my rv with AC and charges the apex when connected to shore power.
I see there is a P050A plug that says input and output but all manuals only mentions this plug for fast charging at EV stations.
The apex300 will be in the garage so using the plug on the device is a less convenient solution
i think you will find that bluetti have completely not thought this one out, as there seems no single 240v outlet that you can couple up into a distribution board. it appears that you would neeed to buy a hub 1 which is several hundred pounds or euro. i cant see why they cant allow the port to be a single 240v output. It is a big setback for using it in a modern rv set up that has 12v and 240v systems
