Apex 300 Working Mode help
I have an Apex 300 with 2 B300K batteries. No solar at this time (yet). I am having a hard time understanding and using the Working modes.
What I want to do is charge everything up to 100%. Then run my AC connections off of the batteries until it reaches a certain percent of discharge, say 30% remaining. Then I want it charge up on the off peak hours and start the cycle again.
When I try and set a SOC percentage they all (different working modes) say; “SoC Low: When the battery drops below this level, grid power will be prioritized to supply your appliances” Great, that’s what I want, but I also want it to charge the batteries.
“SoC High: When the battery reaches the set level the unit will stop using grid power and switch to solar charging for the rest.” I don’t want this. I want it to go back to using the grid and charge the batteries.
I have tried Time Of Use mode with SoC 30% and 80% with Peak and Off peak times defined. But when I am at 80% or more Soc it is still pulling grid power.
I have also tried Custom with the same settings and same results.
I just want to run off of batteries until it hits a certain level then charge up again. Then stop charging and run off batteries.
Basically I want a “Customized UPS” working mode like my Elite 100 V2
Since I don’t have solar yet I just want Grid and batteries. The only way I can achieve this now is by physically unplugging it, waiting a couple of days, check its SoC and then plug it back in.
Am I just not understanding this? Can’t I get it to behave this way? Any help and guidance would be greatly appreciated.
Thank you
Sounds like it is working as designed. To run your appliance off battery ONLY it must be during Peak hours and the SOC % > SOC Low value. Once it drops below SOC Low the Bluetti will switch the appliance to Grid AC Passthru, and the battery can only charge during peak hours via PV. Charge from grid is not allowed during peak hours. You could set your Off Peak hours as 24x7 and use a smartplug to control the grid on/off times and, at least that saves you having to physically plug/unplug the AC. I’m sure some folks have looked into home automation setup where the smartplug on/off is automated based on Bluetti SOC level.
Wow, that actually makes sense… Thank. you I am going to set that up and give it a shot. I have a ton of smart plugs and a (semi) smart home (the home and I are still learning).
Thank you for this.
What happens if the Apex 300 is plugged into 240v grid but running off battery during the time of use and you exceed its inverters capacity? Will it shut off completely or switch to grid power?
