Apex 300: Parallel PV input of 2 different wattage
I have 2 solar panels connected entirely SEPARATELY to separate PV input ports on my Apex 300. My problem: 1x200W Panel and 1x100W panel. Despite separate PV input ports (and I assume separate MPPT) my overall yield is throttled down by the wattage of the smaller panel. (They are wired separately (not parallel or in series. ) What settings on the Apex 300 should I enable to get the full yield from both panels?
“Mixing different wattage solar panels in parallel can reduce system efficiency, as the setup will only produce as much power as the lowest wattage panel allows.”
