Apex 300 P050A port 2 way flow?
Hi, I have a new apex 300 and looking at the best way to charge it and to provide power to my house panel. I know it will charge through this port ( P050A)and I believe it can provide power to the house panel as well? I have a generator that is wired to my panel and I thought I would plug the apex to my compressor plug (240volt) to charge. Then when the generator is off I can feed the house panel through the same compressor plug. Would really appreciate any feedback.
Thanks Chris
Your idea is indeed feasible: you can connect the generator output to the P050A and the AP300 output to the compressor.
However, I would like to remind you that the P050A is primarily used for connecting to the fast charging cable. Charging can also be done through the Y-shaped input port, so connecting to the P050A is not strictly necessary.
If you have any further questions or need assistance, please feel free to reach out.
Доброго дня
Подскажите, хочу купить Apex 300.но не могу понять,где найти кабель R050A
У нас в Украине такого нет?
Я нигде не нахожу такой кабель в продаже :thinking:
Или есть вариант без кабеля P050A.
Что за Y разйом?
Подскажите пожалуйста мне по кабелю R050A
Chrisb - Did you ever get this sorted out?
Live in USA- PNW - Looking to buy Apex 300 and trying to understand option to connect Apex 300 to my 240 VAC Distribution panel (DP) and a generator at the same time. Will be installing a Generator disconnect setup to be powered to DP via a generator from an outside 50AMP Gen Inlet.
Trying to determine how do you connect Apex 50amp PO50A port and charging cable to the DP Gen breaker inlet. Can just add a 50AMp Receptacle for the Apex 300 to the line from the DP to the outside generator inlet?
I am still a little unclear by this. From what I understand, this has a pass-through option where you could have the pass-through plug into a power supply that can receive and transmit. I was hoping that the way I wired it to my panel that I could just leave the plug in charge it when my generator is going, and then when my generator shuts off, it will just reverse power into the panel. Not sure if this makes sense?
Found this incredibly useful video with good discussion of various options.
I think you want the HubA1 kit, with fast charge cable, and a home integration kit (or simple dedicated panel). You can connect 1, 2, or 3 Apex300 to the HubA1 using the dual direction port and the 1, 2, or 3 cables that are sold with the kit (fast charge cord extra).
What it leaves out is the option of adding an Interlock kit (utility power only/off/generator power only) on the main panel. Generator feeds the main panel, Ampex fed from main panel, Ampex feeds disicated circuits in home integration kit. The AT1 kit is a lot more $$.
Am I understand correct, to connect one EU version Apex 300 with full power into distribution power panel for the both directions (input/output) I must have Hub A1? Correct? Even if it is only one Apex 300 unit without Hub A1 there is no bidirectional cable for the P050A connector. Right?
If it is true, will it work with custom cable? Does firmware allow Apex 300 work in UPS mode trough P050A without Hub A1 electronics connected?
I concur with above questions.
I’m looking forward to use Apex 300 and connect to 32A outlet to feed AC to the residential building.
If I want to use only one Apex 300, it there are cable P050A > 32А 230V 2P+PE, or HubA1 is a must even for single Apex 300?
So is the only solution to buy a hub A1?
Plug generator into the PO20A port. then ger cable NEMA 14-50P and end to match the inlet you have. Just plug the 14-50P into the Apex 300. SO you need two cords and then just leave them plugged in all the time.
Since Bluetti can’t make proper EU manual and nobody officially answer on the questions here, so I have purchased two Multiplus-II 5000 GX with four Pylontech US5000. For the same money as Apex 300+B500K (3,8kW/8kWh) I have got 9kW power with 9kWh capacity plus incredible functionality of power assistant with grid, minimum twice overload, tons of additional functions and flexibility.
I am gonna give my answer before I read any of the other comments.
  1. Do not plug into your compressor plug. You can feed back to the grid and kill someone if the grid is down.
  2. Plug your Apex into your generator plug, that’s what it is for. Or is your generator hard wired. There is a lot of unknows of what you have.
    Till I read comments and maybe find more information, the only thing is do not feed back through your compressor plug.
I do not think you understood what he wants to do. He wants to back feed through his compressor plug to run power to his house.
It makes sense if you have an interlock switch in place.
@Photomax I believe in EU and Aus etc, the P050A port supplies max 230v 16.7amps
