Apex 300 error code
Had my new apex running for a week now. It switched to backup mode for bad weather charged battery fully now getting E074 error then when I get the other codes its P024 Cell over voltage protection. Any suggestions?
Hey @Rickyk
seems something BMS related. Did you try to do a calibration process on the Apex?
Hi @Rickyk,
This is what I was able to find regarding the error codes:
Error Code Description Solution
E074 BMS System Fault
(Please check the specific fault in the mobile app)
- Charging temperature too high: Wait for the device to cool down before charging.
- Charging temperature too low: Place the device in an environment with a temperature range of -15°C to 40°C (5°F to 104°F) before charging.
- Discharging temperature too high: Wait for the device to cool down before using.
- Discharging temperature too low: Place the device in an environment with a temperature range of -25°C to 40°C (-13°F to 104°F) before using.
P024 Single Cell Overvoltage Protection Restart the system. If the issue persists, please contact BLUETTI support.
Thanks it was charging from 50% or so all the way to 100% but only at 8 amps. It turned off AC out, kinda cleared itself turned ac out back on no issues. Will try and duplicate.
