Anyone using the original AC200 with Charger 1?
What voltage input or setting do you set it at? I do not see AC200 as an option on the menu.
Hello @Teampark
a warm welcome to the Bluetti community!
Do you know the input range of the AC200s MPPT? Cant find it online. If its up to 60V, you could select the charging profile for AC70, which also have a 60V MPPT.
Just to be safe, @BLUETTI_CARE can you confirm this would work? Or is there any other specific things defined in this charging profiles, beside max voltage?
Hi @Teampark, You have been one of our earliest supporters, and we sincerely thank you for choosing Bluetti!
The open circuit voltage of the AC200 is 35-150V, which is the same as the AC200P.
Yes, you can use Charger 1 to charge the AC200. Please scroll to the custom settings at the bottom and set the voltage to 56V. Alternatively, you can directly select the AC200P model.
Thanks to @Selfmadestrom for the attention and helpful explanation!
