adding b300k to ac500
after connecting the 1st b300k to the ac500 using the p090d cable can we add more b300k batteries by using the p090A cables between the b300k batteries
Perhaps the thread below would help.
Yes, you will need a P150D to P90D cable to connect the AC500 to a B300 or B300K battery. With one cable you can only output 3 kW on the AC500. To get the full 5 kW, you need a second B300 or B300K, and another P150D to P090D on the second AC500 expansion port.
This is not explaindd in the AC500 user guide.
