issue with my AC200MAX since few weeks. And yesterday night one more time. 62% at the evening, turned it off and went to sleep and this morning 0%… It’s not the first time, so I already tried to do one complete (continuous) discharge and charge. But the issue is still there. I’m now recharging from the grid… :-(.
My SN number is AC200M2247000048. Can you help me?
Received. You are expected to receive a push notification of the firmware update within 5 hours.
Please keep an eye on the app and keep it updated at that time, thank you!
@bluetti_john133gmxcom Your SN code was provided incorrectly, so no new firmware could be pushed to you.
Can you check the SN code again? 13-digit Arabic number.
Also, It would be great if you could provide your current BMS version number
@bluetti_john133gmxcom If the situation is still not significantly improved after the firmware update, machine has also done power self-cycling.
Please contact the support team at service@bluettipower.com as soon as possible (provide SN code of AC200MAX, screenshot of firmware and brief description of the problem) to register the return for repair.
