Now, after a couple of days of using the AC70, I have noticed another difference between its operating characteristics and the AC180’s.
With it connected to mains power and a load of no more than 80 watts connected to the AC output, the fan runs continuously.
I am aware of why the fans on the AC180’s turn on and off, but on the AC70, they run at low speed nonstop.
Is this normal?
Room temp 18 degrees Celsius.
Hi @DJR
I can confirm your description. AC triggers around 80W surge. As long you take ~80W or more, the fan will run.
I have a smartphone with 25W charging, the fan is also running after a few minutes when charging.
The air at the outtake is quite warm, so i assume its needed that the fans are running. For what i can see, its normal.
Thanks for confirming.
Appreciated.
