Hi… Just bought a new AC60P unit. Took it out of the box and put on AC mains charger (stable voltage supply in New Zealand). Unit charged to 99% and then temp warning light flashed. Went into SOC menu and found error codes P004 and P007, both of which relate to charge temperature low. Ambient air temp here is 25 deg C, so not cold. Update firmware and turned unit off for several hours. Turned back on and still same problem with temp light flashing, and unit turns off after a few seconds. Not sure what to do now…
@ClintinNZ Is the problem improving now?
If not, please put the machine in a warm place for three hours before charging.
If the alarm shows low temp when charging, try discharging the machine with devices; if it can be discharged, discharge it first and warm up the internal temperature of the machine before trying to charge it.
Hello. My Bluetooth AC 80P complains about a cold battery, although the temperature is normal. Did you manage to solve the problem?
