AC500 Wiring Diagram
Currently I have a AC200Max, but am looking at the AC500 and have seen suggestions of a wiring diagram to connect the unit to my house UK house.
If this could be sent I would be able to review how this integrates into the house wiring and to be able to pass onto my electrician for costing purposes.
Many thanks
@VWcamper
The PDF file of the wiring diagram and related tutorials, I have sent it to you via email. Please check it from forum@bluetti.com.
Hi, could you please confirm how to access the private message.
Sorry to trouble you.
Regards
PM sent, pls check :)
Hi, PM email sent. Thanks
Hi, seems a bit of a hassle, but have sent my PM email again.
Regards
Hi, I have the AC 300 and would like the appropriate diagram as well. How can I get this?
A
@ayo Sure no problem, I need to check with you if you are using the US version AC300?
Hi, it’s the UK version AC300
Pls check the following
Thank you. I take it then that it cannot work in UPS mode with the transfer switch…? I was hoping to use it in UPS mode.
@ayo A single AC300 is UPS-capable, no worries.
Hi,
Two more questions. So this setup will enable automatic transfer to the battery power when grid power fails? That is, I wouldn’t have to make the switch manually?
Secondly, I have seen references to a Bluetti sub panel. Is this no longer available?
Rgds
This is the UPS mode of the machine, and it can be used without a transfer switch. So, it definitely works without the need for manual switching. The transfer switch is just that—a switch.
I would suggest contacting our UK pre-sales service for further verification on this issue: sale-uk@bluettipower.com
