Hello. I hope you’re safe and have power.
The problem disappeared once again after I connected the second b300s battery.
About a week so far, all good.
Yet, here I am again.
Now there is another unexpected behavior, at least for me.
I would like to share this info with you, maybe there is a chance someone else has experienced it before.
It is not the initial issue I started the topic for, but it is strange as well, and also might have the same topic title.
I use bluetti-mqtt to collect some metrics from the power station 24/7 which are then sent to prometheus and used to build graphics in grafana.
Here you will find AC Power metrics (based on ac_input_power and ac_output_power),
as well as SOC metrics (total_battery_percent, pack_details1, and pack_details2),
and of course AC Voltage metric (based on ac_input_voltage).
The data is sent to mqtt broker each 1 second, processed via node-red, and prometheus scrapes data every 5 seconds.
As you can see on screenshots, at 20:36:40 AC500 started to take less than give (input vs output).
And it ended at 20:37:40.
It resulted in dropping SOC on both batteries and they started charging right afterward.
You can also notice that there was no decrease in grid voltage or any significant changes in power consumption.
Since I have set up system monitoring now, I see that it happens regularly, several times a day but no pattern was noticed. But there is always 1-minute drop of AC input and then SOC to 96-99%.
P.S. I also have configured predictive charge/discharge time. It took about 15 minutes. I know I’m not the first one pointing out this, but it’d be great to have it in the app as well.
