I have 2 ac500 and 4 b300s. I have 50 amp plug to charge up both of the ac500. On the output side if I am running split phase can I hook up to the 50 amp plug on 1 ac500 to 1 breaker box and the other ac500 to another breaker box. Or do I have to use fusion box or the split phase output cable that goes back into just one 50 amp service.
@John2
After setting the split-phase mode, you can use a single output port separately. If you don’t need the split-phase output cable, you don’t have to set the split-phase mode.
Kindly be reminded that the difference in load between the two AC500s should not be too large, otherwise, there will be a significant difference in battery levels between the two main units.
Can I charge both the units off one 50 amp service without being in split phase mode.
