I’ve been following this out of curiosity, but wanted to ask about something that seems contradictory. In your original post, you stated that when you turn AC off the phantom power consumption “goes down to zero.” In your second post, you stated when “AC and DC are turned off, the machine shows more then 100W” AC output. I’m confused about the statments appearing to say that power goes to zero and also shows 100+W under the same condition of the AC being turned off. Typo?
Thanks for the clarification; I was just confused. I saw a chart recently that somebody posted which showed some tests (supposedly tested in BLUETTI Lab) with AC500 idle power consumption: 27.4W w/ only AC On, 31.1W w/ both AC & DC On, 12.6W w/ Power On, AC & DC Off. My AC500 doesn’t show any load when on & nothing connected, and even with a load, won’t register anything until the load exceeds about 50W - BLUETTI said this was normal.
I plugged a 100W incandescent bulb into an outlet and it showed 102W. After running it for about 8 hours, the decrease in SOC on the AC500/B300s system did seem to correlate with a power draw of around 130W continuous (light bulb plus inverter consumption). Have you run yours long enough to verify that the power consumption you see on the display matches the rate at which you’d expect your battery’s SOC to decrease? IOW, is it a real current draw from the batteries, or is it a phantom number that only appears on the display?
