AC500 Error 103 BMS Communication Error
I have two AC500 units and while setting them to dual phase received error 103 BMS Communication Error. I disconnected the communication cable, and returned each unit to single phase, but the error will not clear. I then upgraded the firmware, and still no luck.
Anyone have any thoughts or solutions?
TIA
Hi @Rria1965 , This error may be due to a loose communication cable, can you please confirm if the communication cable is plugged in tightly? Thank you.
Good Morning,
Unfortunately I disconnected the cable thinking this would clear the error. Should I reconnect the cable and attempt to clear the error again?
Thank you,
Richard
Good Evening,
I was able to clear the error by reconnecting the communication cable.
Thank you for your patience!
Hi Rria1965, what do you mean? You have bound 2 AC500 to reach more output power?? Thanks
