I’d need your kind help with my AC500+3xB300s system (S/N AC5002241000193290). After having got 5 times an A007 error (Voltage Sensor Error) in about a week, I’ve followed suggestions provided within the Bluetti app by:
- checking if any firmware update for BMS was available (currently, v1022.9). It was not. This is strange because on my other Ac500+1xB300s, the app found a firmware upgrade available for BMS and I upgraded it to v1067.11 !
- then, I performed a SoC recalibration by discharging the batteries to 0% and then charging them w/o any loads connected.
This happend on last Sunday 9th. Today at 12 am, the AC500 stopped working again showing an error 012-BUS Voltage High error. Can you plase advise about how to fix this ?
Many thanks in advance and best regards,
Maurizio Russo
Hi @mrusso70
Did you also check for firmware updates on the B300S? To check and install new updates on them, connect to the AC500 by Bluetooth and click on the percentage on the “main menu” of the unit in the bluetti App.
This should list all you expansion batterys and a button to check for new firmwares.
Hi @mrusso70, We have a new DSP firmware that can fix this issue. Could you please let us know the current DSP version of your AC500? Also, which country version is your AC500? Once we have this information, we will push the update for you.
Thanks to @Selfmadestrom for your attention and input on this matter.
Hi @Selfmadestrom,
I carried out a check on firmware status through Bluetti app and I didn’t find anyone available for batteries. It looks like they are up to date. But, maybe, it is not something I can manage leveraging app functionalities, is it ?
Many thanks for your kind support,
Maurizio
Hey @mrusso70
Please have a look at the answer from BLUETTI_CARE. Seems like they can push a firmware update for you to fix the described issue
Hi @BLUETTI_CARE,
current DSP version of my AC500 (s/n AC5002241000193290) is v4047.30.
I bought it from and I’m using it in Italy, so I suppose the country version is Italy.
Please, be aware I have another AC500 (s/n AC5002248000178717) bundled with one B300S and two B300K. Even in this case, the DSP version is v4047.30. Don’t know if it’d make sense to upgrade DSP for this one in order to avoid same issues in the future.
Thanks in advance for pushing new DSP version as suggested.
Best regards,
Maurizio
Hi Maurizio, We have dedicated DSP firmware to fix this issue. This firmware has not been pushed in bulk because it wouldn’t help most customers who haven’t encountered the problem and might even disturb users.
We have now requested to push this firmware specifically for your first AC500.
Our IT department will push the latest firmware to your unit in 24 hours.
As for your second AC500, if it hasn’t encountered any issues, we do not recommend upgrading it.
Thank you, @Selfmadestrom, for your answers and reminders. That is very kind of you!
Hi,
thank you so much for your kind support. As for now, I didn’t receive the new firmware yet but I will let you know as soon as it is available.
Kind regards,
Maurizio
Hi,
just to let you know that I can’t find any DSP firmware update available for my AC5002241000193290 yet.
Can you kindly check with your IT dept. if any problem occurred pushing the new firmware ?
Many thanks and best regards,
Maurizio
Hi @mrusso70, I am sorry for the inconvenience.
Now we have applied to push the new firmware again.
The new DSP version is v404731. Please let us know if it works.
I confirm you that deployed happened and I managed to update DSP firmware as recommended.
Unfortunately, it didn’t fixed the issue but, rather, I’ve got one further error message. Once I was back home, I checked the AC500 and I found two error messages:
- BUS Voltage High - Hardware
- BUS Voltage High (the same I used to got before upgrading the firmware)
Is there something I can try to do now ?
Maurizio
Hi Maurizio, We recommend that you remove all loads and then restart. Does the error still occur when there is no load?
If so, then it is likely a unit malfunction, and a return for repair will need to be arranged.
Hi @mrusso70, We noticed your comment contained some order details.
For your privacy protection, we’ll delete this comment and continue our conversation through private messages.
Hi BLUETTI_CARE,
here I am again experiencing exactly the same problem (every day I get at least one 012-BUS Voltage High error message).
At this point it occurs to me that the error is not due to the AC500 I am using, since the one I was using in March is no longer there (S/N AC5002241000193290) because I returned it to your repair center in Germany to check whether a mechanical issue was affecting it and you returned it to me in June but it is still packed in my garage 'cause I bought a new one experiencing the same issue now.
I purchased the new AC500 directly from the Bluetti Shop (order #SPF-EN11524 30/03/2025 - S/N AC5002308001304350), which is now paired with the 3xB300S I was already using with the old AC500. Unless you don’t tell me that this is an error always happening with any AC500, most likely the problem is related to one or more battery pack.
Just to avoid you wasting time, be aware I’ve already checked if any firmware was available for my 3xB300S (they’re all up to date) and I’ve already executed the usual procedure to fix the error 012 (discharge + charge wo loads). The error happens again and again. So, please kindly suggest what I can do now. Is there any chance to check if it is due to a battery pack issue ? Have I to dismiss AC500 and replace them with another product (be aware I have 3) ?
I need a truly reliable UPS system supporting critical devices such as security devices, refrigerators, water suppliers so on and so forth. And it has to work without daily human support otherwise it is useless. Any suggestions are more than welcome !
Many thanks in advance for your kind support.
Best regards,
Maurizio
Hi @mrusso70, We would like to know how you installed it and whether you connected the AC500 directly to the home distribution box. Could you take a video to show us the installation and usage scenarios? Please upload the video to a cloud drive and share the link with us.
Please note that the AC500 is an off-grid power supply and requires the installation of a transfer switch. You can test turning on the AC output without connecting it to the distribution box. If it works normally, it means that the transfer switch is not installed or the wiring is incorrect.
When there is no power connection and no load, after restarting and turning on the AC output, does the problem still occur? Please tell us the SN code and current firmware version of your new AC500, and then we will try to push a new firmware to solve the problem.
Hi BLUETTI_CARE,
sorry for delayed response but I’m travelling for work and didn’t pay attention to this issue.
For this reason, I’m not able to take any video about my installation although I believe there’s nothing weird to check. The AC500 is charged by using its original charging cable plugged into the power outlet on the wall. No direct connection to the home distribution box.
Can you please clarify to which transfer switch do you refer to ?
Do you mean that AC500 cannot be charged simply using the charging cable you provide in its box ?
Thanks and best regards.
Maurizio Russo
Hi @mrusso70, Thank you for the update. Please rest assured that the AC500 can be directly charged via the grid using its included charging cable.
We are concerned that you might have connected the AC500 directly to the household distribution box. If that is not the case, then there is no issue, and there is no need to install a transfer switch.
Next, we would like to attempt a firmware update to fix the problem. Could you please let us know the current DSP firmware version of your AC500?
Hi BLUETTI_CARE,
thanks for your feedback. I confirm you that I don’t have any direct connection to the distribution box. I charge it via the grid and I use it to ensure energy to security cameras, a freeze and a router (overall, less than 300W in average).
My current DSP version is v4057.03.
A friend of mine who was experiencing similar issues has now the version v4057.30 and, since he got the upgrade, everything is working fine.
Thanks and best regards,
Maurizio
Hi BLUETTI_CARE,
still waiting for having deployed an updated firmware for current DSP version of my AC500 S/N AC5002308001304350, as per your proposal in the message you sent me 28 days ago, aimed to fix 012-BUS Voltage High error message.
Current DSP Version is v4057.03.
Thanks for your prompt feedback here !
Best, Maurizio
