AC500, B300s
AC500 and B300s give BMS Temperature error. The system will not charge at 50 degrees fahrenheit. The system will not charge with any kind of input. The whole system is unusable if you live off grid and it gets cold. Temperatures are way within charging and operating and it still doesn’t work.
What am I supposed to do living off grid? Bend over backwards to get your product to work? I can’t even charge it with a generator when it’s 50 DEGREES! I have now been totally dependent on a generator for the entire winter.
Hi @Void, We’re concerned that the ambient temperature may not match the internal temperature of the battery cells — the cell temperature could actually be lower than the surrounding environment.
We recommend using a heating pad and creating an insulated enclosure with some ventilation. Would this help in your situation?
Correct me if I am wrong @BLUETTI_CARE , but since @Void is using the b300s batteries with the ac500, the internal heating elements inside the expansion batteries should enable at that temperature and bring the rest of the pack up to temp, as long as he’s plugged into an AC charging source?
My AC500 charges without problems at an ambient temperature of 5°C, and I only have simple B300, which aren’t heated.
I think there’s a different cause in your case.
Hi @Void, Thanks to @m.briney for the reminder — yes, I overlooked the B300S heating function. However, please note that this feature only activates when the AC or PV input power reaches a certain threshold. If the input power is too low, the heating function won’t start automatically.
Also, if the B300S shuts down due to temperatures below 0°C, it will only power back on when the internal temperature rises above 10°C. This is designed to protect the battery from damage caused by low temperatures.
Please try increasing the ambient temperature and input power to help the system warm up, then test again.
Additionally, kindly provide us with the SN code of your AC500 and the BMS version of your B300S so we can check if there’s new firmware available to optimize battery performance.
