I have an AC500/B300S setup, charging from PV panels. I have three 400W panels connected to each of the AC500 DC inouts, and another panel connected to the DC input of the B300S.
I periodically discharge the battery from 90% to 20-30% at 2200W to charge my car.
I am seeing all sorts of odd behaviour - S0C dropping from 20% to 0% over the course of 1-2 minutes, sometimes shortly afer discharge stops, sometimes several hours later, usually resulting in a “D-Bat” drained alarm. I have also once seen a “BMS Overvoltage” alarm.
I have seen other reports of sudden SoC drops, but I have been logging SoC, battery voltage, PV input etc. via the Bluetooth interface. so I have some measurements which might help shed light on what is going on
There is clearly something very broken with the SoC calculation - hopefully these logs will help track down the bugs.
I have also seen it get into a state where it does not charge frem DC-in despite SoC being shown at 25% and vattery voltage at 52V, and only disconnecting the PV and power-cycling the AC500 would recover.
Versions :DSP 4047.30 ARM 4048.0 HMI 6052.034 BMS 1022.08
The full logs can be downloaded here : `Here
Here are some excepts (not sure why some of these are showing in bold)
20:40:28 SoC% 37 V_bat 49.9 W_in_PV 0 I_bat 474 1 W_out_AC 2230
20:40:49 SoC% 37 V_bat 49.9 W_in_PV 0 I_bat 474 1 W_out_AC 2230
20:41:09 SoC% 36 V_bat 49.8 W_in_PV 0 I_bat 474 1 W_out_AC 2232
20:41:29 SoC% 34 V_bat 49.7 W_in_PV 0 I_bat 476 1 W_out_AC 2233
20:41:50 SoC% 30 V_bat 49.6 W_in_PV 0 I_bat 474 1 W_out_AC 2230
20:42:10 SoC% 26 V_bat 49.5 W_in_PV 0 I_bat 476 1 W_out_AC 2229
20:42:30 SoC% 23 V_bat 50.6 W_in_PV 0 I_bat 0 0 W_out_AC 0 SoC sudden drop
07:12:36 SoC% 0 V_bat 51.7 W_in_PV 0 I_bat 3 0 W_out_AC 0
07:12:56 SoC% 0 V_bat 51.7 W_in_PV 0 I_bat 0 0 W_out_AC 0
13:11:43 SoC% 78 V_bat 53.1 W_in_PV 0 I_bat 0 0 W_out_AC 0
13:12:03 SoC% 78 V_bat 53.1 W_in_PV 0 I_bat 0 0 W_out_AC 0
13:12:23 SoC% 78 V_bat 53.9 W_in_PV 610 I_bat 99 0 W_out_AC 0
13:12:44 SoC% 82 V_bat 55.9 W_in_PV 1252 I_bat 252 0 W_out_AC 0
13:13:04 SoC% 85 V_bat 56 W_in_PV 0 I_bat 0 0 W_out_AC 0 SoC rising with no input
13:13:24 SoC% 89 V_bat 55.1 W_in_PV 0 I_bat 0 0 W_out_AC 0
13:13:45 SoC% 90 V_bat 54.7 W_in_PV 0 I_bat 0 0 W_out_AC 0
13:14:05 SoC% 90 V_bat 54.4 W_in_PV 0 I_bat 0 0 W_out_AC 0
15:30:37 SoC% 26 V_bat 49.8 W_in_PV 656 I_bat 337 1 W_out_AC 2247
15:30:57 SoC% 23 V_bat 50.1 W_in_PV 1204 I_bat 233 1 W_out_AC 2243
15:31:18 SoC% 19 V_bat 50 W_in_PV 1205 I_bat 233 1 W_out_AC 2242
15:31:38 SoC% 19 V_bat 51.3 W_in_PV 304 I_bat 64 0 W_out_AC 0
15:31:58 SoC% 19 V_bat 51.6 W_in_PV 594 I_bat 117 0 W_out_AC 0
15:32:19 SoC% 19 V_bat 51.8 W_in_PV 721 I_bat 141 0 W_out_AC 0
…2 hours later - maybe coinciding with PV dropping ?
17:14:37 SoC% 19 V_bat 52.6 W_in_PV 52 I_bat 11 0 W_out_AC 0
17:14:58 SoC% 18 V_bat 52.6 W_in_PV 53 I_bat 9 0 W_out_AC 0
17:15:18 SoC% 18 V_bat 52.6 W_in_PV 51 I_bat 11 0 W_out_AC 0
17:15:38 SoC% 17 V_bat 52.6 W_in_PV 50 I_bat 11 0 W_out_AC 0
17:15:59 SoC% 14 V_bat 52.6 W_in_PV 48 I_bat 9 0 W_out_AC 0 SoC sudden drop with no load
17:16:19 SoC% 10 V_bat 52.6 W_in_PV 48 I_bat 9 0 W_out_AC 0
17:16:39 SoC% 7 V_bat 52.5 W_in_PV 46 I_bat 9 0 W_out_AC 0
17:17:00 SoC% 4 V_bat 52.5 W_in_PV 43 I_bat 8 0 W_out_AC 0
17:17:20 SoC% 1 V_bat 52.5 W_in_PV 40 I_bat 8 0 W_out_AC 0
17:17:40 SoC% 0 V_bat 52.5 W_in_PV 39 I_bat 8 0 W_out_AC 0
17:18:01 SoC% 0 V_bat 52.5 W_in_PV 36 I_bat 8 0 W_out_AC 0
17:18:21 SoC% 0 V_bat 52.5 W_in_PV 34 I_bat 8 0 W_out_AC 0
Sudden drops in PV input - possibly due to high battery voltage ?
11:36:27 SoC% 50 V_bat 53 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:36:48 SoC% 51 V_bat 54 W_in_PV 633 I_bat 104 0 W_out_AC 0
11:37:08 SoC% 54 V_bat 55.4 W_in_PV 654 I_bat 147 0 W_out_AC 0
11:37:28 SoC% 58 V_bat 56.6 W_in_PV 509 I_bat 26 0 W_out_AC 0
11:37:49 SoC% 61 V_bat 55.5 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:38:09 SoC% 65 V_bat 55 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:38:29 SoC% 68 V_bat 54.8 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:38:50 SoC% 70 V_bat 54.6 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:53:44 SoC% 70 V_bat 52.9 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:54:04 SoC% 70 V_bat 52.8 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:54:25 SoC% 70 V_bat 52.8 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:54:45 SoC% 70 V_bat 52.8 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:55:05 SoC% 70 V_bat 53.4 W_in_PV 22 I_bat 4 0 W_out_AC 0
11:55:26 SoC% 74 V_bat 54.9 W_in_PV 647 I_bat 139 0 W_out_AC 0
11:55:46 SoC% 77 V_bat 56.1 W_in_PV 428 I_bat 53 0 W_out_AC 0
11:56:06 SoC% 81 V_bat 55.2 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:56:27 SoC% 84 V_bat 55 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:56:47 SoC% 88 V_bat 54.8 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:57:07 SoC% 91 V_bat 54.7 W_in_PV 0 I_bat 0 0 W_out_AC 0
11:57:28 SoC% 94 V_bat 54.4 W_in_PV 0 I_bat 6 1 W_out_AC 0
11:57:48 SoC% 97 V_bat 54.2 W_in_PV 0 I_bat 6 1 W_out_AC 0
11:58:08 SoC% 99 V_bat 54.1 W_in_PV 0 I_bat 6 1 W_out_AC 0
11:58:29 SoC% 99 V_bat 54 W_in_PV 0 I_bat 6 1 W_out_AC 0
11:58:49 SoC% 99 V_bat 53.9 W_in_PV 0 I_bat 6 1 W_out_AC 0
11:59:09 SoC% 99 V_bat 53.8 W_in_PV 0 I_bat 6 1 W_out_AC 0
11:59:30 SoC% 99 V_bat 53.7 W_in_PV 0 I_bat 6 1 W_out_AC 0
Sudden rise from 24% to 73% over 5 minutes
15:15:31 SoC% 24 V_bat 55 W_in_PV 650 I_bat/10 152 W_out_AC
15:15:51 SoC% 26 V_bat 55.3 W_in_PV 0 I_bat/10 0 W_out_AC
15:16:11 SoC% 30 V_bat 55 W_in_PV 0 I_bat/10 0 W_out_AC
15:16:31 SoC% 33 V_bat 54.8 W_in_PV 0 I_bat/10 0 W_out_AC
15:16:52 SoC% 36 V_bat 54.7 W_in_PV 0 I_bat/10 0 W_out_AC
15:17:12 SoC% 40 V_bat 54.6 W_in_PV 0 I_bat/10 0 W_out_AC
15:17:32 SoC% 43 V_bat 54.5 W_in_PV 0 I_bat/10 0 W_out_AC
15:17:53 SoC% 47 V_bat 54.5 W_in_PV 0 I_bat/10 0 W_out_AC
15:18:13 SoC% 50 V_bat 54.4 W_in_PV 0 I_bat/10 0 W_out_AC
15:18:33 SoC% 53 V_bat 54.3 W_in_PV 0 I_bat/10 0 W_out_AC
15:18:54 SoC% 57 V_bat 54.3 W_in_PV 0 I_bat/10 0 W_out_AC
15:19:14 SoC% 60 V_bat 54.2 W_in_PV 0 I_bat/10 0 W_out_AC
15:19:34 SoC% 64 V_bat 54.2 W_in_PV 0 I_bat/10 0 W_out_AC
15:19:55 SoC% 67 V_bat 54.1 W_in_PV 0 I_bat/10 0 W_out_AC
15:20:15 SoC% 70 V_bat 54.1 W_in_PV 0 I_bat/10 0 W_out_AC
15:20:35 SoC% 73 V_bat 54.1 W_in_PV 0 I_bat/10 0 W_out_AC
15:20:56 SoC% 73 V_bat 54 W_in_PV 0 I_bat/10 0 W_out_AC
drop from 22 to 0% over 2 minutes - approx 30 mins after load was turned off
17:21:12 SoC% 22 V_bat 52.2 W_in_PV 55 I_bat/10 9 W_out_AC 0
17:21:32 SoC% 19 V_bat 52.2 W_in_PV 52 I_bat/10 9 W_out_AC 0
17:21:53 SoC% 16 V_bat 52.2 W_in_PV 51 I_bat/10 9 W_out_AC 0
17:22:13 SoC% 13 V_bat 52.2 W_in_PV 51 I_bat/10 9 W_out_AC 0
17:22:33 SoC% 9 V_bat 52.2 W_in_PV 51 I_bat/10 9 W_out_AC 0
17:22:54 SoC% 6 V_bat 52.2 W_in_PV 51 I_bat/10 8 W_out_AC 0
17:23:14 SoC% 3 V_bat 52.2 W_in_PV 50 I_bat/10 8 W_out_AC 0
17:23:34 SoC% 0 V_bat 52.2 W_in_PV 52 I_bat/10 8 W_out_AC 0 D-BAT drained alarm
17:23:55 SoC% 0 V_bat 52.2 W_in_PV 54 I_bat/10 8 W_out_AC 0
17:24:15 SoC% 0 V_bat 52.2 W_in_PV 51 I_bat/10 8 W_out_AC 0
17:24:35 SoC% 0 V_bat 52.2 W_in_PV 53 I_bat/10 8 W_out_AC 0
17:24:56 SoC% 0 V_bat 52.2 W_in_PV 52 I_bat/10 8 W_out_AC 0
