AC500 /B300 lower the AC input to lowest setting ..how to get into that menu!
How can I reduce the AC input ( charge power) to 1000 watts and lower the amperage to 10 amps? How to get into that menu? I am off grid and do not wish to pull too much power from my solar array. I would rather charge much slower than pull bigger wattage from my system. Additionally I have a 2000 watt generator I wish to use for charging.
Hi @432hertz
You can lower the charging power from AC by adjust the amperage. This can be done in the settings menu of the Machine or in the Bluetti App.
On the Machine, just click on settings and click on next until the point “max grid input” appears. The App should have the same setting visible in the settings too.
