AC500 & AC300: Can They Be Integrated into the Same System?
Hello community, this is my first post, and I would like to ask for some help. Thank you in advance!
Some time ago, I bought an AC300 along with a B300 to improve energy efficiency and reduce the economic cost of the electricity bill at home. Recently, due to the need for better performance than what the AC300 offered, we decided to purchase an AC500 + B300K, and later added a B500K to the system.
My question is: Is it possible to run both the AC300 and the AC500 connected to the same system? I would prefer not to get rid of the AC300, as it’s a great machine, and I’d like to find a way to reuse it.
Thanks for your help!
Thank you for your inquiry. You can use the AC500+B300K/B500K system for high-power loads (such as air conditioners, water heaters, and kitchen appliances) while using the AC300+B300 system for low-power loads (such as lighting, outlets, and small appliances). These two systems can be wired independently and isolated via a dual power switch or circuit breakers to prevent load cross-sharing of the power generation and charging sources.
If you have any other questions or need further assistance, please feel free to contact us!
