AC300 with b230
I have a b230 battery, can I use it with a AC300?
It means: does the AC300 run with a b230 as the only battery?
Bluetti literature would have you believe the b300 or b300s is needed. I wonder if anyone has ever tried it though? It should plug in physically the same. I suspect the b300 has a higher amperage rating, one that aligns with the ac300.
Another thing can be a different voltage. B300 have 58.8V Charging Input. Maybe B230 have less Input/Output Voltage and its doenst align with AC300.
I only can find AC300 with B300 combinations.
