When I use my Bluetti AC300 in UPS mode connected to a grounded AC utility power outlet, is all my connected equipment properly grounded as well?
Thanks. I read something about these devices having a “floating ground” and I don’t know what it is. Somewhere I read it meant “no connection to ground at all” but I’m glad everything is properly grounded when I connect my equipment to my AC300 while my AC300 is connected to a properly grounded outlet.
Please don’t worry. As long as the power grid is grounded, connecting the charging cable to the BLUETTI machine means it is grounded. ![]()
Yes, the grid and outlet is properly grounded. I tested it with an outlet tester.
I also tested the output of my AC300 and it is fine according to the tester as well. I just did not know what floating ground is and it confused me a bit. I’m glad all is fine.
