AC300 touchscreen and power button
I got the AC300 over a year ago. I charged it up with the batteries and then kept in storage.
I checked it to day to top up the charge. The 4 B300’s held the charge well ( with a little top up) but the 2 AC300’s don’t turn on ( power button and screen) even when there is an input from the house outlet.
When I connect the AC to the B, the B power button turns on.
Are both the AC’s so drained that it’ll take time?
could they be broken?
please help me get the AC’s back to working order
thanks
You can’t charge the AC300 because it doesn’t have a battery inside.
The AC300 isn’t a standalone product. It always needs to be connected to at least one battery pack to work.
@Lawrie AC300 does not have an internal battery. If you connect AC300 with the battery and the system works, then there is no problem with it.
