AC300 - PV Input Reduces with space heater 1.4kw load
New owner here. AC300 and 2 B300
So, now that I have my PV up and working on both controllers (3- Renogy 320 per controller), it seems like when I am charging (works well), and then I turn on the space heater, OR reduce the space heater settings, the PV input drops dramatically, over 1/2, this when I am over 80% full on both. Is this normal? Or is the ac300 just adjusting on the fly???
Which DSP firmware version are you using? I had a similar issue, and DSP firmware v4031.25 fixed the issue for me.
I have DSP v4031.16…does not say I need to update. how do you do that?
@LukeWarm Please provide me with the SN of your AC300 then I will push the firmware for you.
SN ac30022220000439442
batteries discharge at different rates as well
@LukeWarm Thank you. The firmware was pushed your your AC300, please check.
For this problem, please check if there is a new BMS firmware, if yes, please update to the latest one. Also, please do a full cycle of charge and discharge to correct the SOC.
@LukeWarm Hi, is there any updates?
After the updated firmware and the recharging the batteries from zero, everything seems to be woking fine. PV shows continual state and the output shows the continual state. Now I need more batteries, 2 is a minimum…of course…
@LukeWarm Thanks for your update.
