I’m having a problem with a new AC 300 unit that I just purchased. I am trying activate the “Grid self adaptation” feature under the advanced settings menu within the phone app, but when I go to enable this function, the “Enable” button is greyed out and does not allow me to enable the mode. I’ve updated to the latest firmware, but no change. Does anyone know if there is any other way to enable this feature or correct this issue in the app?
What firmware(s) version are you using?
Is your AC output enabled? Is it drawing power from the grid right now? What is your max grid input current set to? Mine is just two button saying enable vs disable.
iot 9014.13
Arm 4032.11
DSP 4031.30
BMS 1014.16
I actually wonder why this is even an option vs always on. Is there some compromise when it is enabled?
