AC300 Grid Power Adjustment not possible
The grid current on the AC300 can no longer be changed. Neither pressing the predefined values nor entering a user-defined value changes the setting. The value that I assigned at the beginning during setup always remains active at 3A. I am using a 230V version with the latest FW. What am I doing wrong?
Daniel
Try signing out of the app and logging back on.
@Scott-Benson I will do that, but what will it be good for? The current is not set via the app, but on the AC300 display.
@d.hed Please provide me with the SN and the firmware version of your AC300 and I can check if there is a suitable firmware for you to test.
My bad, I was thinking you could adjust the charge rate in the app
For information, if it is a European-standard machine, the silent mode must be turned off when adjusting the AC input current.
I updated the AC300, switched the silent mode off and was able to reduce the current.
Thanks to everyone for help!
Daniel
@d.hed Thanks for your update.
