My Ac300+B300 loses an average of 1% battery life per hour with absolutely zero output or load on the system, accept being powered on. Is this a normal discharge rate for the batteries with no output load?
thanks
thanks
As for the AP200M owner’s perspective, it seems normal if you have AC on.
Yes, I noticed the same thing with my AC500 + B300S (x2). Parasitic drain from just having the system on. I would suggest disabling all inputs/outputs when not in active use. Especially the AC output.
