I would like to use my AC300 as an emergency generator for my gas boiler and an eletrical underfloor heating. Both are in the same circuit and both are permanently installed and must be should also work with circuit braeker (FI). But I need a defined neutral conductor and a PE (earth wire). Can I define the neutral conductor on the AC300 by connecting PE with one conductor.
