videos show 2 AC300 with 2 B300 each connected to a split phase 240v…
can we add 2 more B300 to each AC300 for a maximum of 24kw hours
Hi @azwhitehawk00
For what i can see, there arent any setups with more than 2 per Unit.
@BLUETTI or @BLUETTI_CARE Could you confirm if 2 or 4 B300 are supported with split phase?
Hi @azwhitehawk00, Thank you for your attention to Bluetti.
Yes, that’s correct. Each AC300 supports up to 4 B300 or B300K batteries, even in split-phase mode.
Thank you, @Selfmadestrom, for your attention and response to this matter.
Yes, you can. My setup has four B300 batteries (two on each expansion port) for each of the two AC300. I have a total of eight B300 batteries for 24kWh at 240 VAC.
