Is there anyway to boost the bluetooth signal so that i can be in the house with it outside?
Short answer - No. Bluetooth has an approx range, line of sight of 10M (33ft). This can significantly reduce due to walls and other obstructions. I have a Bluetooth Shunt in my car, am sitting in my caravan at a range of 2.5M and it won’t connect due to the steel of the car and aluminum of the caravan. ![]()
Yes, you can get extenders, but they need to plug into the transmitter, which is in the AC2A and has no plug.
