AC240 UPS Mode Requires two AC240 in parallel?
Hi all,
I was reading the user manual for the AC240 and noted the UPS Mode section calling for 2 AC240 in parallel to use the “Standard UPS Mode”. This can’t be true can it???
@dannyboy753 Welcome to the forum!
AC240 standalone, these UPS modes can be set;
AC240 parallel, only the standard UPS mode can be set.
So, the text should read “This is the only UPS mode available when two AC240 units are connected in parallel”. The way it is written now implies that “Standard UPS Mode” is only available when two AC240 units are connected in parallel. It would be good to change the manual on this point.
Thank you for the clarification. Agree with hnymann text should be rephrased.
@hnymann @dannyboy753
The suggestion has been received. I will submit it to the manual writing department.
I appreciate that you respond to these messages, and I enjoy being able to make a good product even a little bit better. :+1:
