AC240/RV Setup
I recently purchased a Bluetti AC240 and am looking for guidance on the best way to integrate it with my small travel trailer.
I have a 2019 nuCamp T@G with a 12V marine lead-acid battery and the factory small solar panels mounted on the trailer.
I understand that I can simply plug the trailer’s 30-amp shore power cord into the AC240, but I also realize that this is not very efficient since it converts DC → AC → DC just to run my 12V loads (lights, TV, fan, etc.).
What I’d like to do instead is properly use the AC240’s 12V / 30A DC output to power the camper’s DC system directly.
My goals are:
  • To power the trailer’s 12V DC system directly from the AC240
  • To disconnect the trailer’s 12V battery while using the AC240
  • To be able to switch back to the trailer battery when the AC240 is not in use
  • To avoid backfeeding or damaging either system
What is the correct and safe way to wire this?
Do I need a DC-DC charger, selector switch, or other components to do this properly?
Thanks in advance for any advice or diagrams — I want to make sure I do this the right way.
The first thing you need is the RV Power Cable, noted on page 10 of your user manual. This will allow you to connect to the 30A/12V RV outlet of the AC240. Do a search AC240 on the Bluetti sales web site, it shows a diagram of Aviation plug to XT60 and the second cable of XT60 to a SPC45 Anderson connector.
To achieve your switchover as explained, you need a battery switch with 3 positions. Position 1 connects your trailer battery to the system, position zero is a centre position - OFF and position 2 connects your AC240 to the trailer system.
3 Position Battery Switch
This is the type in Australia, but do a search in your location, lol.
