Hi Bluetti team, I have that annoying fan behavior(it start at high speed every 2 minutes for 10-20 seconds) when using AC even if power is low. temperature in my appartments is 20-21C. I don’t understand why it’s done that way? Do you have any updates to change this behavior? Maybe make softer start of fans and at lower rpms, but for longer period of time and make wider temperature delta(cool down to lower temp) to reduce cooling start/stop frequency, so it will be not that loud and annoying.
