AC200Pl - Incorrect AC load & Grid self-adaptation trouble
Model: AC200PL
SN: AC200Pl2546110162486
BMS: v1056.03
ARM: v2140.06
DSP: 2130.13
Problem 1 - Incorrect AC load readings: when connecting two laptops and one monitor, the AC load reading shows 0 watts.
However, if the same load is connected to another AC70P device, the AC load reading shows 70-110 watts.
Sometimes, when connecting an additional load, the AC load reading shows around 50 watts, and when disconnected, the AC load reading returns to 0 watts, even though two laptops and one monitor remain connected.
Video
Note: The AC load reading via USB is correct.
Problem 2: The Grid self-adaptation setting doesn’t work in the app—when I try to set the values, nothing happens.
Tried on Android and iPhone—the behavior is the same.
Video
@BLUETTY_CARE, can you help?
