Hello there! I bought AC200PL and B210P. But cable from the boxes is not suitable. I can’t connect the power station to the battery. I find information at the bluettipower site. But I can’t understand which one is correct of them:
P090D To Aviation
Applicable Models: AC200L, Length: 42.5in/1.08m.
P090D To DC7909
Applicable Models: EB150/EB240/AC180,Length: 59in/150cm.
P090D To XT90
Applicable Models: Applicable Models: AC200/AC200P, Length: 59in/150cm.
@Rymba
The standard cable of the B210/P is only suitable for connecting the AC240/P.
Yes, you need a P090D To Aviation cable (Aviation Plug also known as M28).
Thank you so much!
That cable is so complicated to find.
Does the B210P work with AC200PL as a power bank or an additional battery?
I am thinking about changing B200P to B300 (it has a clearer connection system and more capacity).
Good morning from New Zealand! New user to Bluetti, but a bit disappointed. Have connected B210P to my AC200PL and, while it charges via the ac200pl, it will not give power back! the green diodes indicate 80% full but my AC200PL died. yes, connected correctly via the cord in recommended in this thread. please help :-)
@TamJ Hi Tam, Welcome to the forum!
Please focus on checking the battery connection cable: the aviation plug connected to the B210 needs to be locked, please twist it to see if it is locked in place; P090D port also needs to be locked too.
After shifting the system for the builders, not locking was exactly the problem. Thank you very much. Now off to search for why my AC200PL is not charging from generator today, when it did yesterday and the day before…oof
Hello! Could you please clarify a moment with the expansion batteries. I have a setup of AC200PL and B210P connected via P090D To Aviation cable. I want to expand the system capacity by adding a bigger battery, for example B500K, which is stated as a compatible with AC200PL via regular P090A cable. But is it possible to have these two batteries connected to AC200PL at once? As AC200PL connected to B500K via P090A and the other port of B500K connected to B210P via P090D To Aviation cable? Thank you
