Hello.
In the setup with AC200PL(or AC200L)+B300, what will be the charging speed and time if using only AC input into the station?
AC200L/PL charging speed is 800/1200/2400 for each mode. Let’s say I use standard, 1200W.
Will it charge internal battery fast, but the expansion battery will be charged from the station with only 500W max, taking > 8 hours in total?
Or are they charged at the same time with high speed?
Will AC300 or any other unit charge external battery sugnificantly faster? I am now purchasing station+battery setup and need this to decide which one. I kind of need everything to be able to charge in 4 hours max.
Thank you.
