Ac200pl + b300 + b300k?
Hello!
I have AC200PL + B300.
If I want to add another battery, should it be B300 or B300K?
I don’t mind capacity difference, but will different batteries work fine or are there any disadvantages and I should use 2 of the same?
Also, it seems there is a fan inside of B300K, unlike B300, is that correct? Does B300K heats up more? My B300 seems to be completely cold and silent.
Thank you.
@snmya
With one AC200PL+B300, you can add at most one B300 or B300K. Both B300K and B300 have built-in fans. You can compare their parameters and prices to choose the one that suits your needs better.
Hi, thanks for answering.
Yes, I undestand that is technically possible, I’m asking if it will be good config, having 2 different batteries. Will there be any compatimility or SOC issues, and if it would be better to have 2 of the same instead of 300+300K.
P.S. Strange about fan, in B300 there are no holes in plactic to the outside world, so if it works, it just moves hot air around in closed case. That’s why I assumed it isn’t there.
Theoretically, identical battery packs will be more synchronized. In practice, there are no issues with compatibility, and the differences in SOC are minimal.
Привет
Подскажите пожалуйста можно ли одновременно подключить к станции AC200pl батарею B300k и B210p
Есть ли такая возможность и будет ли оно корректно работать с зарядкой розрядкой?
Спасибо
Hi, I have the same unit as topic starter has but on official website it is stated that b300k battery is not compatible with AC200PL and I do not know if I can buy the battery and it will work with it?
It works.
I doubt there is statement on the official website it is not compatible. PL is just not mentioned at all sometimes, being improvement on L. So where L is mentioned, it also applies to PL.
But I agree, website should be improved in this regard.
Thank you for your feedback! You’re right, the official website should indeed clarify this relationship better. I will provide feedback to improve this.
Unfortunately it does not work… Whan I connect AC200PL to b300k it shows an error that inverter is overloaded (AC and DC blinking with gear icon on main screen). When I connect b300k as a second battery to B300, it does not count the b300k… Maybe there is something I need to do in settings?
I did not do anything in settings, it just worked. Mine are connected AC->B300->B300K. I had AC+B300 and later added 300K.
Have you tried connecting 300K to AC with cable that works with B300, maybe the second one is faulty? Is it locked on both ends?
Does AC & B300 have latest FW (by latest I mean about year ago)?
