Finally installed my new PV350 today and put her out. I’m getting 22.4 voltage input but no power. Panels are not in ‘SUPER STRONG’ direct sunlight, but they are getting sunlight and still nothing in terms of input power. Any suggestions?
The AC200P needs a minimum of 35 volts for charging. A single PV350 panel is within this range and should be able to charge assuming you are exposing the panel to direct clear sunlight. Make sure that you have “PV” selected in the input settings screen and are not mistakenly using the “Car” setting.
