AC200P will not charge on AC
AC200P has been working great in my van, chagring off solar and AC (via pure sine inverter)
Today it is not charging from AC power.
The charging block/power converter has a green light. On the screen sometimes it shows 51 volts but ZERO watts.
I tried shutting it off
What else can i check?
thanks
Does it charge with AC from a different power source? Also do you have the adapter to enable you to connect your AC power brick to the aviation (solar input) input port? If so, try that charging method and if successful you know your charging brick is ok.
@hertfordnc If the car charging and PV charging work, the charging brick or the AC input port may be defective.
