AC200P charging from solar
Hi everyone. I have an off-grid cabin in Maine and have an AC200P I use for lights, kitchen stove lighter, and occasional small appliance use. I’m very happy with the unit, but would like to hook it to a 200W ecoworthy solar panel I’m mounting that would only charge this unit.
Questions:
-will the unit charge when it is “off”?
-does it turn on and off automatically to charge? (not the ac/dc outputs)
-does the unit have a built in solar charge controller, or will I need one?
-is a 12V 200W panel going to be enough voltage, or should I use 2, 12V, 100W panels in series for 24v?
Thanks for sharing the expertise.
Hi @Maineiac
1 no it won’t charge when off.
2 it will turn on when enough sun and turn off if eco is turned on after a few hrs with no draw.
3 yes it has built in mppt controller.
4 use your 2 100 panels to 24v
@Ktt , Kerr, point 4 Is not ideally correct, it may, or not, work. The PV input range (Soc) of the AC200P is 35V to 150V, I have one.
I have 2 x 150W panels with a Voc of 21.04V, but under load a Vmp of 18V. In Series the Vmp is 36V and that is in ideal conditions. In less than ideal conditions the voltage is lower. The other array I have, is 2 x 160W panels, Voc of 23.85 and Vmp of 20.05 = Vmp in Series of 40.1, they will work better, but again not ideal.
If you really want to make a dent in charging 2,000Wh of battery, I would suggest either 2 nominal 24V panels in Series for a 48V input, or 4 x nominal 12V in Series for a similar 48V array. The Voc will be up toward 90V.
As the solar input limit is 700W, Which is rarely met, overpanelling 4 x 200W 12V panels (or 2 x 200W - 24V panels) Will work and get close to your maximum solar input. As you already have 2 x 200W - 12V panels, get 2 more of the same type. :slight_smile:
As an aside to my reply, I can gang my 4 panels all in Series for a total of the Sum of their Vmp values multiplied by the lower of the 2 Imp values. i.e. Total Array of 620W. Which is; 18+18+20.8+20.8 =77.6V x 7.69Imp = 597W of the 620W rated output. 7.69A is the lower of the panel’s Imp values. A 23W loss is acceptable to me for slightly mismatched panels.
Why I chose 12V panels - I also have 2 x AC70s, 3 x AC180s and the Elite 100 v2. Their Voc max values range from 58V to 60v and 2 x of either array will work, but 4 will not. The Elite 100’s 60V - 20A input, does allow me to Parallel each string and then connect the 2 strings in Series to use all 4 panels. This simply doubles the Vmp and the Imp, less a little.
I also have an AC2A, with an input limit of 28Voc - 8.2A, which only 1 panel can be used to charge it. This setup means I can charge any of my power stations from any of my panels, with differing configurations, but obviously not all at the same time lol.
AI says that when AC200P goes off, Eco Mode is reset to the default - off, and if the unit turns back on for charging, will stay on?
Is this incorrect?
